[Gdal-dev] 2 problems on GDAL/OGR-1.3.2
Tue Nov 14 12:38:15 EST 2006
Jean-Daniel GONON wrote:
> Hi,
> nobody has ideas or solutions for my problems in these 2 mails ?
>> Now I have 90 errors in Visual C++ : " gdal error LNK2019: symbole
>> externe non résolu _ObjectName
>> référencé dans la fonction _ObjectFunction "
Jean-Daniel,
I have no idea about this.
> 2°    > Which are the operations to add new OGR format in GDAL/OGR
> (under windows XP) ?
>> It's an evolution of DGN format to version 8.
>> I already start by making a copy of the
>> gdal/ogr/ogrsf_frmts/old_format directory as
>> gdal/ogr/ogrsf_frmts/new_format, and modify (filenames and functions
>> names) accordingly.
>> After I add the new registration entry point at the bottom of
>> gdal/ogr/ogrsf_frmts/ogrsf_frmts.h, and call it from
>> gda/ogr/ogrsf_frmts/generic/ogrregisterall.cpp.
>> But the new format isn't detected by ogrinfo.exe when I want to open a
>> DGN version 8 file.
>> What I must then declare or modify ?
I also don't know why this isn't working.  But I would suggest you
figure out whether your new driver is listed when you do "ogrinfo --formats".
If not, then investigate whether the registration call is actually being
called in ogrregisterall.cpp.  If so, then I would suggest adding debug
messages in your open function to see if it is being invoked at all.  If
not, perhaps a previous driver is trying to open the file, and failing.
Normally each driver is tried in turn till one either succeeds or one
fails issuing an error.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
