[Gdal-dev] OGR: VRT
Wed Nov 15 14:09:22 EST 2006
Stephan Holl wrote:
>   n2n_wert (Real) = 95.59999999999999   <--- strange, should be 95.600
>   n2n_idflm (Integer) = 1207
>   n2n_wertdat (String) = 2004-12-31
>   n2n_idflaeche (String) = 04000000
>   frmt_wert (String) = 95,600
>   format_wert (String) = 95,600
> Is this a known problem?
> I am on Debian with gdal-1.2.6
Stephan,
I'd suggest trying again with the latest version (ie. a nightly cvs
snapshot) and see if the problem persists.  There have been a lot of
changes and improvements since 1.2.6.  If the problem persists you can
file a bug report, hopefully with an sql script we can execute in mysql
to initialize an example table showing the problem.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
