[Gdal-dev] Release 1.4.0
Andrey Kiselev dron at ak4719.spb.edu
Thu Nov 16 07:39:05 EST 2006
On Wed, Nov 15, 2006 at 09:32:51AM -0500, Frank Warmerdam wrote:
> >should it be possible to include the correction of this bug
> >http://bugzilla.remotesensing.org/show_bug.cgi?id=1009
> >in release 1.4 ?
> The bug requests a OGRStyleTool destruction method to ensure
> the delete occurs in the same heap where they are created.  It seems
> like a very good idea.
> Would you like to propose a patch I can apply?  I make relatively little
> use of the ogr style classes and methods and am generally hesitant to
> change them.
> Andrey - since you are working in this area currently perhaps you would
> be willing to take this bug report?
Ok, I did a change to deallocate objects in the destructor. Also I have
made a change in the ogr_featurestyle.h to hide data members from the
public sections, so, folks, you will probably need to make clean before
rebuilding the fresh cvs tree.
Best regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
