[Gdal-dev] Release 1.4.0
Frédéric Trastour support at geoimage.fr
Thu Nov 16 10:45:58 EST 2006
Andrey,
> Ok, I did a change to deallocate objects in the destructor. Also I have
> made a change in the ogr_featurestyle.h to hide data members from the
> public sections, so, folks, you will probably need to make clean before
> rebuilding the fresh cvs tree.
I can't see any changes in the cvs; have already put this correction in the cvs ?
Thanks anyway for the bug correction,
Frederic.
