[Gdal-dev] geographic coordinates in PCI files
Wed Oct 11 10:21:50 EDT 2006
Vikalpa Jetly wrote:
> I am finding that gdalinfo or using the dataset.GetProjection() method
> returns the coordinate system as null “”, for PCI files with a
> geographic coordinates (Lat/Long WGS84 or NAD83). For other coordinate
> systems like UTM, I am getting correct values. What am I missing here?
Vikalpa,
I have confirmed the bug in GDAL and have applied a fix.  If you need
the fix, you can grab from CVS or put the following file in your gdal/ogr
directory and rebuild.
   http://www.gdal.org/srctree/ogr/ogr_srs_pci.cpp
Thanks for the bug report!
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
