[Gdal-dev] geographic coordinates in PCI files
Vikalpa Jetly vjetly at i3.com
Wed Oct 11 18:04:08 EDT 2006
Thanks Frank. I have no experience with building GDAL from source, so I'll
hack a sort of 'assume geographic' solution for such cases till these get
passed in the next binary release.
Vikalpa
Vikalpa,
I have confirmed the bug in GDAL and have applied a fix.  If you need
the fix, you can grab from CVS or put the following file in your gdal/ogr
directory and rebuild.
   http://www.gdal.org/srctree/ogr/ogr_srs_pci.cpp
Thanks for the bug report!
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
