[Gdal-dev] Bool vs int in bindings?
Simon Perkins sy at perkins.net
Tue Apr 3 01:01:05 EDT 2007
A lot of the SWIG generated binding functions use ints as arguments and
return types when a boolean type would be more appropriate, e.g. the OGR
Open() method takes an int as the second argument to indicate whether
the file should be opened with update access, and the
SpatialReference.IsGeographic() method returns an int. It would be nice
to use a more natural bool in these cases for languages that support it.
Would I be right in thinking that there's pretty much no way of changing
this now without breaking a lot of code? What about just changing it for
some of the newer bindings, e.g. C#, that have recently had breaking API
changes applied anyway. I like the new enums, etc for the C# bindings in
place of int constants, can we fix the bool vs int problem there as
well? I'd be happy to do this if people want to fix it, and Tamas
doesn't have time.
And while we're changing this, should wkbGeometryType be WkbGeometryType?
Cheers,
Simon
