[Gdal-dev] Error building gdal/ogr: undefined reference to `_gfortran_ ...
Hernán De Angelis dhdeangelis.listas at gmail.com
Mon Apr 23 07:30:31 EDT 2007
Hi all,
I am trying to build gdal/ogr. I did many times before without
problems but this time I continuously get this error:
g++ ogrinfo.o -o .libs/ogrinfo  /usr/local/src/gdal/.libs/libgdal.so
-L/usr/local/lib -L/usr/lib -L/usr/lib/lib -ljpeg -lgeotiff
-L/usr/local -L/usr/local/pgsql/lib -lpq -lz -lrt -ldl -lpthread
/usr/local/src/gdal/.libs/libgdal.so: undefined reference to `_gfortran_shape_4'
`_gfortran_internal_malloc'
/usr/local/src/gdal/.libs/libgdal.so: undefined reference to `_gfortran_size0'
`_gfortran_reshape_4'
`_gfortran_internal_unpack'
`_gfortran_internal_pack'
`_gfortran_string_trim'
`_gfortran_string_len_trim'
`_gfortran_copy_string'
`_gfortran_internal_free'
collect2: ld returned 1 exit status
make[1]: *** [ogrinfo] Error 1
make[1]: Leaving directory `/usr/local/src/gdal/ogr'
make: *** [ogr-apps] Error 2
This happens almost at the end of the make process, when building ogr.
I am using openSUSE 10.2, gfortran-4.1 and gcc-4.1. The error is the
same in both gdal-1.4.1 and svn checkout, so it is likely an issue in
my machine. I have no clue about the reason, so any hint will be
appreciated.
Thanks in advance
Hernán De Angelis
Linux user # 397217
