[Gdal-dev] Reducing GeoTIFF color depth from 24 bit to 8 bit
Matthew Perry perrygeo at gmail.com
Wed Aug 22 17:55:35 EDT 2007
On 8/22/07, Rich Signell <rsignell at usgs.gov> wrote:
> Is is possible to use GDAL to reduce the color depth of a GeoTIFF from
> 24 to 8 bit?
Check out the rgb2pct.py utility.
Matthew T. Perry
http://www.perrygeo.net
"You never change things by fighting the existing reality.
To change something, build a new model that makes
the existing model obsolete" - R. Buckminster Fuller
