[Gdal-dev] Reducing GeoTIFF color depth from 24 bit to 8 bit
    Frank Warmerdam
    warmerdam at pobox.com
    Wed Aug 22 18:25:42 EDT 2007
Rich Signell wrote:
> GDAL folk,
> Is is possible to use GDAL to reduce the color depth of a GeoTIFF from
> 24 to 8 bit?
> I've looked at doc and e-mail archives for 20 minutes and haven't
> found it yet - hoping someone can spend 30 seconds on the answer!
> My work around is to reduce the colordepth in Irfanview, but then I
> need to add the georeferencing info back in again with gdal_translate.
>  This works, but there must be an easier way.   This is all because
> our ship's navigation software (HYPACK) doesn't seem to like 24 bit
> GeoTIFF, but 8 bit is fine.
Rich,
The rgb2pct.py python script (available in FWTools builds for instance)
can be used to convert 24bit images to paletted 8bit images.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
