[gdal-dev] Scripting OGR and KML
Brian Hamlin maplabs at light42.com
Mon Dec 10 03:38:54 EST 2007
On Dec 9, 2007, at 1:01 PM, Brian Hamlin wrote:
> So the Question is this:
>  In OGR terms I see the Layer, Features and Geometry.. A Feature has a
> FeatureDefinition.
>  In KML terms, a Layer is a Folder, and Features are the Placemarks. I
> can see by conversion testing that a Layer/Folder can have a name ,
> and Feature/Placemark can have a Name and a Description. The
> description can be quite long.
>   But using the class interfaces in a script, I dont see how to set
> these things.  ???
>   It looks like the name in a Feature Definition could be the name of
> a Placemark. But that leaves Layer - Name, and Feature - Description
I found that after creating a Layer from a KML datasource and creating
a feature based on the Layer definition, Feature->SetField() can be
used to set pre-existing 'Name' ad 'Description' fields.
Reading the documentation and examples regarding FeatureDefn and
FieldDefn still leaves me puzzled
I put two sample perl scripts on Trac under code snippets
Feedback is welcome
best regards
   -Brian
