[gdal-dev] GDAL 1.5.0 Beta2 Released
William Kyngesburye woklist at kyngchaos.com
Tue Dec 11 16:49:28 EST 2007
On Dec 11, 2007, at 2:49 PM, Christopher Barker wrote:
>> I went the route of building explicitly and  separately for each
>> system version.
> > It's easier to compile that way,  and to install.
> well, yes and no. If you are building a 10.4 (I get confused as to
> which cat is older than which -- at least Ubuntu puts their animals
> in alphabetical order!) compatible version, then a 10.5 one is just
> extra work -- which is fine if you are doing it!
The problem is the new 64bit stuff in leopard.  I first started with
one build for Tiger & Leopard.  This is a lot of work - build 32bit
universal with the 10.4 SDK, build 64bit universal with the 10.5 SDK,
lipo the two together for a quad-arch binary (and make sure I don't
miss any in a complex package).
Then, on install, for Tiger strip out the 64bit parts.  I found a
annoying trap on Tiger - it has limited 64bit support (but not enough
for GDAL and most of the other frameworks), and will try to run 64bit
binaries on 64bit processors, which will usually fail.
>> I'm not sure what the problem is with Leopard's Python, if any.
> Partly it depends on how you want to use it. For one, I often need
> to build py2app's bundles for re-distribution -- if I use the 10.4
> Universal Framework build, then I cover a lot of bases.
Which I can't do, because I build separately for each platform.  But,
the binaries can be linked to in other software however is desired -
ie link to the Leopard framework binaries with the 10.4 SDK, run on
Tiger (with the Tiger framework binaries installed).
>> There was some debate about it on the python list, but I don't
>> remember any serious real issues (but then, a lot of the extensions
>> that were discussed aren't of interest to me).
> Well, these are the ones I know of:
> - no readline
But does use libedit.
> - weird mixture of 32/64 bit quad libs and 32bit libs (though I
> don't think that breaks anything)
A lack of 64bit carbon.  Which is probably why Apple made the Python
executable 32bit-only.
I actually build my GDAL Python bindings 64bit-enabled.  But since the
python executable is only 32bit, gdal python will only run 32bit,
unless someone has a 64bit python executable.  I'm planning on looking
into compiling just the python executable 64bits to match Apple's and
run the GDAL autotests with that - as long as nothing tries to load a
python extension that needs carbon (nothing in GDAL), it should work.
Sadly, the python GUI stuff uses carbon.
>> I guess I'll see what happens when I try the GRASS python GUI on
>> Leopard...
> yup.
> Anyway, If you're going to do anything -- please support the 10.4
> python. Beyond that, anything else you do is gravy -- and believe
> me, I appreciate it all.
The Tiger bindings should work off a Leopard GDAL framework - the
system version compatibility issue has nothing to do with the GDAL
API.  If you're willing to try I can make a GDAL Python standalone
installer that will install the Tiger bindings on Leopard...
>> Actually, the windows eggs DO need an external gdal.
> hmm, that's unfortunate -- again -- it makes me want a Linux style
> package manager!
I think this applies to all platforms for GDAL.  It's just the way the
GDAL bindings work.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
