[gdal-dev] Building Gdal 1.5 beta on a 64 bit system
Steve Popovich cartrite1 at yahoo.com
Wed Dec 12 11:29:23 EST 2007
Frank Warmerdam wrote:
Are you possibly using an external libtiff?
Yes I was. I rebuilt with ./configure --without-libtool --with-python --with-libtiff=internal
and the autotest results were:
 ------------ Failures ------------
Script: ogr/ogr_geom.py
  TEST: ogr_geom_empty ... fail
    IsEmpty returning false for an empty geometry
Test Script: osr/osr_ct_proj.py
Succeeded: 646
Failed:    1 (0 blew exceptions)
Skipped:   222
GDAL 1.5 enabled .aux.xml file creation and reading by default
OK. I was just curious as to why the extra files.
In another reply
Steve,
I'm not at all clear on what is going wrong.  I build on 64bit linux as
 my
main work environment, so I think we need more detail to help you.  It
might be worth filing a Trac ticket, and include an appropriate chunk
 of
the actual error output.
I'm new to this environment and never did a trac ticket so I'll have to look into it.
For now I'll try to add a little more info.
I built gdal-1.4.4 with a standard devel installation on openSuse10.2 x86_64.
This is the first time I tried to build something and had to install extra deps.
The first link error was with LibSM.la. I had that file in /usr/lib64 but not /usr/lib
I installed xorg-x11-libSM-devel-32bit and got past that link error only to fail at the next.
I then installed all the x11-devel-32bit files and then failed linking to libidn.
openSuse10.2 does not have a 32bit devel package for libidn so I gave up.
That is when I configured --without-libtool and everything worked.
This is the first time in all the pkgs I built over the last 4 years that I had to build
with the --without-libtool option. As you can see from above that it works but is this
acceptable or is something wrong with libtool creation?
Steve Popovich
Looking for last minute shopping deals?  Find them fast with Yahoo! Search.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071212/90056da4/attachment.html
