[gdal-dev] Setting up a StatePlane Coordinate system
    Christiaan Janssen
    cjanssen at iavo-rs.com
    Fri Dec 28 14:31:59 EST 2007
Could someone point me to (or provide me) a code snippet that shows how one would go about setting up a State Plane zone based OGR Spatial Reference object. Every attempt I've made has resulted in a SRS object that when used with OGRCreateCoordinateTransformation() function always results in a failure because there is no conversion from it. Thanks
Christiaan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071228/18cb2e08/attachment.html
