[Gdal-dev] Converting to GMT
Jose Luis Gomez Dans josegomez at gmx.net
Tue Feb 13 03:00:04 EST 2007
Joaquim,
> >I get the following error:
> > gdal_translate -of GMT test.tif testOut.grd
> > Input file size is 1347, 1032
> > netcdf: 3 is not a valid cdfid
> I just tried that transformation and it worked ok (1.4.0 on Win XP)
> It only failed to convert the
> NoData Value=-99999
> to NaN as is expected for the default value on GMT grids
Hmmm, it also works fine on Win2k (GDAL 1.3.1.0, FWTools 1.0.0a6, released 2005/11/03), but fails on my Linux box, and with the latest GDAL installed. i wonder why?
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
