[Gdal-dev] Shapefile and SpatialRef problem
Tue Jan 9 12:53:58 EST 2007
Gauthier,Jean-Philippe [CMC] wrote:
> 	You're right, I just added the \n in the .prj file and it works.
> I did use gdal from fwtool 1.1.3 that I got this morning. Seems it going
> to hev to be rebuilt.
Whew!
I can issue a 1.1.4 if this is a big hassle for you, or you could revert
to FWTools 1.1.2 which shouldn't have the problem.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
