[Gdal-dev] Shapefile and SpatialRef problem
Gauthier,Jean-Philippe [CMC] Jean-Philippe.Gauthier at ec.gc.ca
Tue Jan 9 13:04:21 EST 2007
	I will revert to 1.1.2 until you issue a 1.1.4, guess it should
not be a mather of months
	Thanks.
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: 09 January, 2007 12:54
To: Gauthier,Jean-Philippe [CMC]
Cc: Gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Shapefile and SpatialRef problem
Gauthier,Jean-Philippe [CMC] wrote:
> 	You're right, I just added the \n in the .prj file and it works.
> I did use gdal from fwtool 1.1.3 that I got this morning. Seems it
> going to hev to be rebuilt.
Whew!
I can issue a 1.1.4 if this is a big hassle for you, or you could revert
to FWTools 1.1.2 which shouldn't have the problem.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
