[Gdal-dev] ogr2ogr
Thu Jan 25 08:22:04 EST 2007
Gennady Khokhorin wrote:
> Frank,
> I'm debuging ogr2ogr and have couple questions about program structure.
> 1. Should --config "GDAL_DATA" be applyed in ogr2ogr command? If so I dont see
> args handling --config in ogr2ogr.cpp. How this variable gets into the code?
> 2. What the story with OGR_DRIVER_PATH, GDAL_DRIVER_PATH in OGRSFDriverREgistrar::AutoLoadDrivers()?
> Should I set it up at run time?
Gennady,
I see Mateusz has covered off config variables in some detail.
Normally you should not need OGR_DRIVER_PATH and GDAL_DRIVER_PATH.  They
are really for the special circumstance where some drivers are being
handled as plugins.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
