[Gdal-dev] Re: nmake for c # interfaces
kevser sonmez kevsemola at gmail.com
Tue Jul 3 04:21:41 EDT 2007
Hi again,
By getting a snapshot from the cvs the error has gone related to that tiff
But I have another problem;
The test data wouldnt work and the system.typeinitializationexception is
thrown by the ogr.registerall() command.
I searched for the mailing archives, the error seems to be related with the
missing of some required dll's. (proj.dll or some other) But actually I dont
know which dlls should be referred, that is should be on the path??
Another question is, I cannot refer to the wrap.dll s from the csharp
project (e.i. csharp_wrap.dll) from a csharp project, is this normal?, it
complains about that dll is not a COM component or a valid assembly? I dont
know much of C #, so sory :((
And the last question is, is c# is complete in terms of the ogr, I mean; Is
everything; that can be done in the c++ API, can also be done by using the
c# bindings?
And to mention, I am working with visual studio 2005, in an 64 bit windows
XP...
Cheers
Thanks a lot for the contributions :)
On 7/2/07, kevser sonmez <kevsemola at gmail.com> wrote:
> Hi,
> I have been trying to build the gdal and swig files using the nmake
> utility, for the csharp part of the swig (csharp seems to have the good
> documentation :) ). When I try to build the gdal core library, it seems to
> fail at the frmts directory for the tiff library. It gives the error,
> " This version of tif_config. h header is dedicated for Windows CE
> platform !"
> I can produce the four namespace dll s for the c# interfaces but since I
> cannot produce the core gdal library with the nmake, the linking cannot
> succeed.
> I am trying to compile it for a win64 bit system and setting the WIN64=YES
> options in the nmake.opt file and also in the comandline when calling for
> nmake.
> Any ideas are geratly appreciated ...
> Thanks in advance :)
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070703/541e075d/attachment.html
