[Gdal-dev] How to Use gdalwarp to Convert to Simple Lon/Lat?
Kent Eschenberg eschenbe at psc.edu
Thu Jul 19 16:36:48 EDT 2007
What are the options for gdalwarp that will produce an image on a simple
longitude/latitude coordinate system?
The input file, lambert.tif, is a GeoTiff file from the National Atlas using
the Lambert_Azimuthal_Equal_Area projection. It covers the 48 states.
I'd like the output X pixel coordinate to represent equally-spaced values of
longitude and Y to represent latitude.
I tried this:
    gdalwarp -t_srs "+proj=ortho +lat_0=45 +lon_0=-100 +x_0=0 +y_0=0"
       lambert.tif ortho.tif
I took the values for "+lat", "+lon", "+x_0" and "+y_0" from the input.
gdalwarp wouldn't work without them.
This is a huge map so I've looked at only a 4000x3000 piece from the upper-left
corner. ortho.tif looked the same as lambert.tif. The U.S.-Canadian border was
curved in both. That doesn't seem right.
"gdalwarp --version" yields "GDAL 1.4.2.0, released 2007/06/27". I'm using a
Redhat Fedora Core 5 system.
TIA!
Kent
