[Gdal-dev] How to Use gdalwarp to Convert to Simple Lon/Lat?
ValiSystem vali.system at free.fr
Fri Jul 20 05:18:03 EDT 2007
On 19 juil. 07, at 22:36, Kent Eschenberg wrote:
> What are the options for gdalwarp that will produce an image on a
> simple longitude/latitude coordinate system?
> The input file, lambert.tif, is a GeoTiff file from the National
> Atlas using the Lambert_Azimuthal_Equal_Area projection. It covers
> the 48 states.
> I'd like the output X pixel coordinate to represent equally-spaced
> values of longitude and Y to represent latitude.
> I tried this:
>    gdalwarp -t_srs "+proj=ortho +lat_0=45 +lon_0=-100 +x_0=0 +y_0=0"
>       lambert.tif ortho.tif
> I took the values for "+lat", "+lon", "+x_0" and "+y_0" from the
> input. gdalwarp wouldn't work without them.
> This is a huge map so I've looked at only a 4000x3000 piece from
> the upper-left corner. ortho.tif looked the same as lambert.tif.
> The U.S.-Canadian border was curved in both. That doesn't seem right.
> "gdalwarp --version" yields "GDAL 1.4.2.0, released 2007/06/27".
> I'm using a Redhat Fedora Core 5 system.
> TIA!
> Kent
You can use ESPG:4326 which is the lat/long projection on the WGS84
datum. This should be exactly what you expect.
gdalwarp -t_srs EPSG:4326 lambert.tif ortho.tif
