[Gdal-dev] Reproject with Mapserver vs gdalwarp
José Vicente Higón josevicente.higon at gmail.com
Wed Jul 25 05:05:16 EDT 2007
I configured a layer in Mapserver which datasource was an ECW image in
EPSG:23030. When I requested the layer in other reference system like
EPSG:4326, I got an error, the image was shift some meters. We solve the
problem modifying the epsg file in proj directory with this line:
<23030> +proj=utm +zone=30 +ellps=intl +towgs84=-87,-98,-121,0,0,0,0 +units=m
+nadgrids=sped2et.gsb +no_defs  <>
and adding the file sped2et.gsb in the same location as the epsg file. With
these changes Mapserver worked fine and the error disappeared.
My surprise was when I tried to reproject a raster with gdalwarp:
gdalwarp -of HFA -s_srs "EPSG:23030" -t_srs "EPSG:4326" source.ecw dest.img
I got the image with the shift error, in fact, I got the same image before
made the changes in the proj file.
In both cases I was using the latest FWTools release (1.3.4)
Why Did I get differents results in MApserver and gdalwarp?Any clue?
Thanks in advance
José Vicente Higón Valero
Grupo desarrollo gvSIG.
IVER TI S.A.
C/Salamanca, 50-52 46005-Valencia
Tlf.+34963163400
http://www.iver.es
http://www.gvsig.com
http://www.gvsig.gva.es
