[Gdal-dev] Measured Values for Shapefile read & write
    Frank Warmerdam
    warmerdam at pobox.com
    Thu Jul 26 10:29:31 EDT 2007
Nelson, Dean wrote:
> Frank, et al,
> I agree - its not a datum issue here.
> I have tried the solution suggested by Frank with no change in the
> results. However, in delving deeper into the data for this particular
> project, it appears that all of this data is off about 10 min in Lat. I
> can't explain it - so I'll ask the source: USGS - which may prove to be
> a daunting task for a whimp like me.
> In the mean time I would like to know a few techniques to get me through
> the day:
> 1. If I have a shape file that is 10 min off in lat, how can I shift it
> to the right spot with the GDAL/OGR tools? Or do I need to write a
> little code?
Dean,
The vec_tr.py script can be used to to shift or scale vectors.
   http://trac.osgeo.org/gdal/browser/trunk/gdal/pymod/samples/vec_tr.py
You will need to edit the TransformPoint() function in the python script
to modify the point(s) as you wish:
def TransformPoint( xyz ):
     x = xyz[0]
     y = xyz[1]
     z = xyz[2]
     x = x + 1000
     return (x,y,z)
Just replace the x = x + 1000 line with whatever you want.
> Since I am dealing with 1km resolution hydrology basins, accuracy is not
> a huge concern.
> 2. When I reproject with ogr2ogr, the data come out 0-360 longitude. How
> can I make it +-180?
Gee, you are raising hard issues.  Try setting the CENTER_LONG configuration
variable before the reprojection.  This is supposed to trigger "rewrapping"
of longitudes around an alternate center.
eg.
ogr2ogr -t_srs WGS84 --config CENTER_LONG 0 out.shp in.shp
But I'm surprised you are getting 0-360 output from ogr2ogr reprojection.
It normally defaults to -180 to 180.  I wonder if something odd is going
on.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
