[Gdal-dev] matching metadata for different file formats
Matt Fearon matt at guero.sr.unh.edu
Thu Jun 28 15:48:07 EDT 2007
Dear GDAL users:
I am converting grib files to netcdf as a 1st step using ncar command
language. netcdf is an easier format for me in the long run for data
storage. After this 1st step, I would like to reprojected my data from
polar stereographic to geographic. The datum of the polar stereographic
is unique in that data are mapped to a sphere with radii 6371200 km.
Here is my trouble:
If I skip the 1st step and simply reproject the grib data to geographic
using gdalwarp everything works perfectly. However, if try to reproject
the data after the 1st step, I am unsuccessful. I am also performing
some simple calculations on the data before going from grib to netcdf,
but I am not changing the coordinate system, projection, datum
etc...Some of the metadata is lost going from grib to netcdf, and
therefore, I apply gdal_translate to the netcdf file adding the lost
metadata back in and converting the format to geotiff. However, after
these steps, I still notice some slight differences in the metadata
between the original grib and the geotiff. I am struggling to make the
metadata consistent for 3 parameters (GEOGCS, DATUM, and SPHEROID),
please see metadata comparison at the base of this email from gdalinfo.
Any suggestions on how I can make these 3 parameters consistent between
files would be much appreciated. Perhaps some combination of options
using gdal_translate? Although, I have tried many combinations
unsuccessfully, and therefore, the data do not map correctly. gdalinfo
may be excluding some information as well. However, everything is
consistent with the metadata except these 3 parameters. My original data
are hourly NEXRAD precipitation, mosaicked over the CONUS at 4km, in
grib format, polar stereographic projection assuming the Earth as a
sphere with radii of 6371200 km, downloaded from NCEP. I am converting
hourly to daily and storing in netcdf for various projects.
thanks in advance for the help,
Matt
Driver: GRIB/GRIdded Binary (.grb)
Files: gag4.19980201.01
Size is 1160, 880
Coordinate System is:
PROJCS["unnamed",
  GEOGCS["Coordinate System imported from GRIB file",
      DATUM["unknown",
          SPHEROID["Sphere",6371200,0]],
Driver: GTiff/GeoTIFF
Files: 19980201.tif
Size is 1160, 880
PROJCS["unnamed",
  GEOGCS["unnamed ellipse",
      DATUM["unknown",
          SPHEROID["unnamed",6371200,0]],
