[Gdal-dev] Subversion changes
Sun Mar 4 23:34:38 EST 2007
Folks,
Howard has made the changes to GDAL's subversion and for somewhat esoteric
reasons, the old subversion url no longer works.  So a small change should
be made in your root "gdal" directory if you want an existing tree to continue
to work.
Do:
svn info
And look for the URL line.  Something like:
URL: https://svn.osgeo.org/svn/gdal/trunk/gdal
If this line has https: then do the following in the same directory:
svn switch --relocate https://svn.osgeo.org/svn/gdal https://svn.osgeo.org/gdal
If the URL line is using http: then do this:
svn switch --relocate http://svn.osgeo.org/svn/gdal http://svn.osgeo.org/gdal
By the way, I'd strongly discourage using http: for anyone doing commits.
Please only use http: for anonymous checkouts, and use https for any
tree where you plan to make changes back to the master.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
