[Gdal-dev] ogr2ogr - delete features from a shapefile
Sun Mar 4 23:47:07 EST 2007
keith lewis wrote:
> How can I delete features from a shapefile using the ogr2ogr utility?
> The shapefile driver documentation indicates I should first delete the
> appropriate records from the DBF file and then repack the file. Can
> ogr2ogr do this or does it need to be done in code?
Keith,
I don't believe that ogr2ogr or any of the commandline utilities offer
a mechanism to delete layers.  You need at least a small script to be
able to invoke the DeleteLayer() method on the OGRDataSource.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
