[Gdal-dev] problem compiling 1.4.0 on mac os x 10.4
William Kyngesburye woklist at kyngchaos.com
Tue Mar 6 15:44:37 EST 2007
On Mar 6, 2007, at 12:48 AM, Eric Dönges wrote:
> Am 05.03.2007 um 23:43 schrieb John Cartwright:
>> Hello All,
>> I'm having a little trouble compiling 1.4.0 on my mac.  The 1.3.x
>> series compiled just fine on the same machine.  Lots of messages
>> like:
>> /usr/bin/ld: warning multiple definitions of symbol _get_crc_table
>> /usr/local/src/gdal-1.4.0/.libs/libgdal.dylib(single module)
>> definition of _get_crc_table
>> /usr/lib/libz.dylib(crc32.o) definition of _get_crc_table
>> Any ideas?
> You are having a linker conflict between the libz internal to GDAL
> and the system's
> libz. To resolve this, you need to either not link against the
> system's libz in any
> files linking against libgdal, or configure gdal to not use the
> internal libz
> (try configuring with --without-libz or --with-libz=external - I
> haven't tried this
> myself, but one of the above should work). Since doing the former
> might be rather
> difficult in practice, and MacOS includes libz by default anyway, I
> would recommend
> trying the later.
That's odd.  I've never specified any libz options in configure, and
it finds the system libz by default.  FWIW, I think the only thing
that needs libz is the HDF formats with SZ compression enabled in the
HDF libraries.
PS. have you tried using my GDAL framework?  Or do you need the unix
library build for OSX?
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
