[Gdal-dev] DTED Performance on Windows
Jason Beverage jbeverage at prologic-inc.com
Tue Mar 6 18:56:43 EST 2007
Hi Martin,
The performance is basically the same for all the DTED 2 files that I've
tried.  If I convert the file to a geotiff using gdal_translate it only
takes about 2 seconds to load the file.
Thanks,
Jason
-----Original Message-----
From: Chapman, Martin [mailto:MChapman at sanz.com]
Sent: Tue 3/6/2007 5:21 PM
To: Frank Warmerdam; Jason Beverage
Cc: gdal-dev at lists.maptools.org
Subject: RE: [Gdal-dev] DTED Performance on Windows
Jason,
If you can send me the dted or tell me which one it is (I have the NGA
DTED Library) I will test it on windows for you and let you know How
fast I can load it for a comparison.
Martin Chapman
SANZ Inc.
Software Developer
http://www.earthwhere.com
W - 303.495.6326
C  - 303.898.0397
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Frank
Warmerdam
Sent: Tuesday, March 06, 2007 9:48 AM
To: Jason Beverage
Subject: Re: [Gdal-dev] DTED Performance on Windows
Jason Beverage wrote:
> Hi all,
> I'm having some issues with the DTED driver, especially on Windows.
I'm
> attempting to read an entire DTED 2 into memory using a single
RasterIO
> call, and I found that performance is horrible.  I read in a mailing
> list post that setting the cache size to be about 30 MB would increase
> the speed, and it does, but performance is still pretty bad on
Windows.
> I ran a simple test loading the DTED with a single RasterIO call on my
> 3.0 Gz P4 windows machine and it takes about 2 minutes to load the
file
> with a cache size of 30 MB.  On my 1.2 gz Mac Mini G4, it only takes
> about 6 seconds to load the file with a 30 mb cache.
> Does anyone have any suggestions on how to speed up performance on
> Windows or have a more efficient way to load up DTED data?
Jason,
If you can file a bug report on this, I'll have Mateusz look into what
is
happening.   Other than cache thrashing, I can't think of any reason
this
should be noticably slower on windows than anywhere else.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
