[Gdal-dev] current svn fails to compile, ersdataset.cpp
Thom DeCarlo t.r.decarlo at larc.nasa.gov
Fri Mar 16 11:29:15 EDT 2007
(I'm sorry if you get this twice. I'm not sure about the first address I
sent it to.)
I'm getting an error when compiling ersdataset.cpp in the current svn.
ersdataset.cpp: In static member function 'static GDALDataset*
ERSDataset::Open(GDALOpenInfo*)':
ersdataset.cpp:527: error: 'class ERSHdrNode' has no member named 'FindElem'
ersdataset.cpp:533: error: 'class ERSHdrNode' has no member named 'FindElem'
ersdataset.cpp:539: error: 'class ERSHdrNode' has no member named 'FindElem'
ersdataset.cpp:545: error: 'class ERSHdrNode' has no member named 'FindElem'
And, sure enough, it doesn't exist in the ershdrnode.* files. Is there a
check-in missing for this change?
Thom
this sig intentionally left blank
