[Gdal-dev] OGR PostGIS driver problems on x86_64
Edzer J. Pebesma e.pebesma at geo.uu.nl
Fri Mar 23 08:22:37 EDT 2007
Mateusz,
I tried to reproduce the bug with a fresh rgdal/ogr install from
subversion/trunc, and couldn't. Apparently it has been resolved since
1.3.2, which debian etch uses.
thanks for the explanation about my misuse of ogr2ogr; I will read
harder next time!
Edzer
Mateusz Loskot wrote:
> Edzer J. Pebesma wrote:
>> I'm running debian testing ("etch") on a x86_64 architecture; when I
>> run
>> ogr2ogr -overwrite -f "PostgreSQL" "PG:dbname=postgis" meuse.shp
>> it gives me a segmentation fault. [...] Is this a known problem? How
>> can I (help to) resolve this?
> Edzer,
> I don't suppose it's a known problem.
> Please, could you submit a bug report about this problem:
> http://bugzilla.remotesensing.org/enter_bug.cgi?product=GDAL&component=OGR_SF
>> A related but less serious issue is that the layer name is ignored:
>> on the 32 bits architecture
>> ogr2ogr -overwrite -f "PostgreSQL" "PG:dbname=postgis" meuse.shp mmm
>> will not add a table; after removing mmm table meuse will be written,
>>  after renaming the shapefile into mmm.shp (etc) mmm will be written.
>> A layer name different from the shapefile name causes it not to be
>> written; no layer name will result in the shapefile name being
>> written. Is this documented behaviour?
> Are you trying to overwrite layer name from "meuse" to "mmm"
> and you expect to achieve this by specifying layer name after
> meuse.shp file ?
> If my diagnosis is correct, then you are misusing the ogr2ogr utility.
> Please, refer to the manual:
> http://gdal.org/ogr/ogr2ogr.html
> and read about -nln option.
> Also, in the PostgreSQL driver manual:
> http://gdal.org/ogr/drv_pg.html
> you can find example showing how to import data with custom layer name
> specified, still using -nln option.
> Cheers
