[Gdal-dev] How to debug
Sat May 5 19:08:04 EDT 2007
Stephen Woodbridge wrote:
> Hi all,
> I downloaded the gdal-1.4.0 tarball and copied nearblack.cpp and the
> GNUmakefile changes needed for it. I can compile it but the executable
> is a libtool shell script. How can I get an executable that I can run in
> gdb?
> I assume I can "make install" it but I don't want to do that until I
> have tested and debugged it.
Steve,
First, keep in mind you need to set the CFG environment variable to
"debug" to get GDAL to build with debug info (ie. add -g to cflags).
Second, you can do "gdb .libs/nearblack" to use the actual executable
with the debugger.
Third, you can instead configure using --without-libtool and build
to avoid the libtool indirection shell scripts.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
