[Gdal-dev] gdalinfo -stats on raw binary data
John Cartwright John.C.Cartwright at noaa.gov
Fri May 25 16:30:58 EDT 2007
Hello All,
I have the same data in three different formats: 16-bit signed integer
(*.bin), 32-bit signed integer (*.bin), and 32-bit float (*.flt).  I'm
not getting the correct answers when I run "gdalinfo -stats", the min
and max should be -6488 and 1320 respectively.
The (seemingly incorrect) response I get is the same for each file:
Driver: EHdr/ESRI .hdr Labelled
Size is 4801, 2401
Coordinate System is `'
Origin = (-68.000416665000003,19.000408664999998)
Pixel Size = (0.000833330000000,-0.000833330000000)
Corner Coordinates:
Upper Left  ( -68.0004167,  19.0004087)
Lower Left  ( -68.0004167,  16.9995833)
Upper Right ( -63.9995993,  19.0004087)
Lower Right ( -63.9995993,  16.9995833)
Center      ( -66.0000080,  17.9999960)
Band 1 Block=4801x1 Type=Byte, ColorInterp=Undefined
  Minimum=0.000, Maximum=255.000, Mean=153.351, StdDev=98.734
  NoData Value=-32768
Should I be forcing these to a different driver or modifying the
associated hdr file in some way?
Thanks for your help!
-- john
