[Gdal-dev] Transparent PNG with color table (palette)
Ludwig M Brinckmann ludwigbrinckmann at gmail.com
Mon May 28 06:45:55 EDT 2007
I need to create paletted PNG files with transparency.
I understand that I need to pass in a colour table with the alpha channel
set to 0.
As I cannot create PNGs directly, I first create a Tiff with the colourtable
and then do a CreateCopy.
But when I then look at the PNG colour table, the transparency values are
gone (all set to 255). This is also true for the intermediate Tiff file --
which is understandable as single band tiffs don't do transparency. I think
when creating the tiff the colourtable is adjusted so that it works for the
Tiff, but then my transparencies are lost. (If someone thinks this is a bug,
I will turn my code into a short example).
I tried to alter the colour table after creating the tiff (or the createCopy
of the PNG), but this is not supported.
What's the best way to do this -- maybe I just need a better intermediate
format that does transparencies and can be created (which one?)
Any hints?
Regards
Ludwig
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070528/ae0fb059/attachment.html
