[Gdal-dev] First Leopard build results for GDAL 1.5
William Kyngesburye woklist at kyngchaos.com
Fri Nov 2 13:17:42 EDT 2007
On Nov 1, 2007, at 11:38 PM, Frank Warmerdam wrote:
> William Kyngesburye wrote:
>> Running tests from ogr/ogr_dods.py
>>  TEST: ogr_dods_1 ... ERROR 4: couldn't connect to host
>> fail
>> I've never got this one to connect.  Other dap tests also fail with
>> I/O warning : failed to load external entity "data/ais.xml"
> William,
> I woldn't worry about the DODS tests.
Is there a way to skip tests in the autotests, apart from removing
their python script?  Or could this feature be added (is there a bug
trac for autotests?)?  The dods test takes a while to timeout, so it's
a bit annoying.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
