[Gdal-dev] First Leopard build results for GDAL 1.5
Frank Warmerdam
warmerdam at pobox.com
Fri Nov 2 13:31:45 EDT 2007
William Kyngesburye wrote:
>>> Running tests from ogr/ogr_dods.py
>>> TEST: ogr_dods_1 ... ERROR 4: couldn't connect to host
>>> fail
>>> I've never got this one to connect. Other dap tests also fail with
>>> I/O warning : failed to load external entity "data/ais.xml"
>> William,
>> I woldn't worry about the DODS tests.
> Is there a way to skip tests in the autotests, apart from removing their
> python script? Or could this feature be added (is there a bug trac for
> autotests?)? The dods test takes a while to timeout, so it's a bit
> annoying.
William,
I normally just remove the scripts I don't want to run, but of course then
they pop back next time I do a checkout. There is a GDAL Trac "Category"
for autotest stuff, so feel to file a ticket on this.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
