[Gdal-dev] status of ldshared build? (or,
	other options for OSX framework build)
    Christopher Barker
    Chris.Barker at noaa.gov
    Fri Nov  2 15:42:54 EDT 2007
William Kyngesburye wrote:
>> It sounds likethe OS-X port of libtool is broken and/or incomplete --
>> are the libtool developers open to fixing this kind of stuff?
> Libtool is not "broken", it just doesn't have the ability to directly
> create a binary of the framework style
I did say "or incomplete". Anyway, my point was that, according to the
libtool web page, the goal of libtool is to provide one interface to
building and installing shared libs. IN order to support OS-X, it should
be able to build standard Frameworks, so I was wondering if the libtool
devs are open to adding this functionality.
My other question is: are you trying to build what Apple could consider
a "standard" framework, or something that's a mixture of regular old
libs and a Framework?
> So the
> current GDAL makefile lets libtool do its thing, then renames it and
> changes its internal link path during installation.
OK, so I'm still confused as to why you need to hand-alter (or makefile
alter) anything in the python package -- aren't all the changes needed
in the GDAL Framework?
In my case, it looked like the python extension was looking for:
/Library/Frameworks/GDAL.framework/Versions/1.5/libgdal.1.dylib
where there already is:
/Library/Frameworks/GDAL.framework/Versions/1.5/GDAL
and:
/Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib/libgdal.dylib
I know it's kludgy, but couldn't we put yet another link in to what
python is looking for? The right way, I suppose, is to get it to look in:
But I'm still confused as to how that path is being set.
Maybe this is it, from setup.py:
     libraries = ['gdal']
     library_dirs = ['../../.libs','../..']
     extra_link_args = []
That's how it finds the libs when it's building, but how does it know to
look in the Framework when installed?
>> build GDAL
>> install GDAL lib (framework on OS-X)
>> build python extensions (using installed GDAL)
>> install python extensions
>> would that work better?
> Yes, that is a possibility.  But the current GDAL python setup.py
> doesn't work that way - it looks for the source-built copy of libgdal.
This just seems odd to me, and I'm surprised it isn't causing problems
on other platforms. I guess it comes down to the idea of what are shared
libs for? I think they are for, well, sharing the same libs among
various programs, in this case, the various gdal utilities, anything
built to use gdal, and the various language extensions.
In this case, it seems the normal route is to install the shared libs,
then build the stuff that depends on them. I think that would work
better in this case, and I think all it would take to build that way is
to put something in the setup.py like:
extra_link_args=['-framework', 'GDAL']
I'll poke into this some more, if you like.
>> >>> distutils.sysconfig.get_python_lib()
>> '/usr/lib/python2.5/site-packages'
> That's a good possibility, and what I was looking for.  I'm just not up
> to speed yet on Python ;)
It took me a while to find it.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
