[Gdal-dev] status of ldshared build? (or, other options for OSX framework build)
William Kyngesburye woklist at kyngchaos.com
Fri Nov 2 17:03:20 EDT 2007
On Nov 2, 2007, at 2:42 PM, Christopher Barker wrote:
> William Kyngesburye wrote:
>>> It sounds likethe OS-X port of libtool is broken and/or incomplete
>>> -- are the libtool developers open to fixing this kind of stuff?
>> Libtool is not "broken", it just doesn't have the ability to
>> directly create a binary of the framework style
> I did say "or incomplete". Anyway, my point was that, according to
> the libtool web page, the goal of libtool is to provide one
> interface to building and installing shared libs. IN order to
> support OS-X, it should be able to build standard Frameworks, so I
> was wondering if the libtool devs are open to adding this
> functionality.
I don't follow libtool development.  Since OSX has been around for a
while, and libtool has been thru many versions since, and I don't see
support in the 2.x development, I doubt it will happen.  The future
directions page on the libtool site doesn't mention anything about
frameworks.
> My other question is: are you trying to build what Apple could
> consider a "standard" framework, or something that's a mixture of
> regular old libs and a Framework?
The end product is a normal framework.  But even Apple uses the
"mixed" type - see the OpenGL framework, which includes libGL and
libGLU as separate library files.  But they don't recommend others
doing that (though I did for a while).
>> So the current GDAL makefile lets libtool do its thing, then
>> renames it and changes its internal link path during installation.
> OK, so I'm still confused as to why you need to hand-alter (or
> makefile alter) anything in the python package -- aren't all the
> changes needed in the GDAL Framework?
> In my case, it looked like the python extension was looking for:
> /Library/Frameworks/GDAL.framework/Versions/1.5/libgdal.1.dylib
> where there already is:
> /Library/Frameworks/GDAL.framework/Versions/1.5/GDAL
> and:
> /Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib/libgdal.dylib
Exactly.  Libtool builds it as
Before installation, python links to that.  Then the GDAL install
renames it to
and needs to tell the gdal python libs the same (install_name_tool).
The unix/ stuff is just a convenience for other unix software that
doesn't know about "-framework GDAL".
> I know it's kludgy, but couldn't we put yet another link in to what
> python is looking for? The right way, I suppose, is to get it to
> look in:
As you say, kludgy.  And messy.  I want to get it right.
> But I'm still confused as to how that path is being set.
> Maybe this is it, from setup.py:
>    libraries = ['gdal']
>    library_dirs = ['../../.libs','../..']
>    extra_link_args = []
> That's how it finds the libs when it's building, but how does it
> know to look in the Framework when installed?
All OSX libraries embed the full path to theirselves.  The linker then
embeds that into other libraries that link to them.  You can see this
with:
otool -L /path/to/some/library/or/program
>>> build GDAL
>>> install GDAL lib (framework on OS-X)
>>> build python extensions (using installed GDAL)
>>> install python extensions
>>> would that work better?
>> Yes, that is a possibility.  But the current GDAL python setup.py
>> doesn't work that way - it looks for the source-built copy of
>> libgdal.
> This just seems odd to me, and I'm surprised it isn't causing
> problems on other platforms. I guess it comes down to the idea of
> what are shared libs for? I think they are for, well, sharing the
> same libs among various programs, in this case, the various gdal
> utilities, anything built to use gdal, and the various language
> extensions.
It's an OSX problem, just for the framework build.  If you build GDAL
as a dylib on OSX (which is exactly what the framework build does,
really), and install in some standard location like /usr/local, the
python linking won't have this problem.  But then you don't have the
nice packaged framework that is so much easier to install and
uninstall than the library.
> In this case, it seems the normal route is to install the shared
> libs, then build the stuff that depends on them. I think that would
> work better in this case, and I think all it would take to build
> that way is to put something in the setup.py like:
> extra_link_args=['-framework', 'GDAL']
> I'll poke into this some more, if you like.
This is a possibility, even in the current build-everything context.
It just needs a another flag: -F../.., and the framework would have to
be assembled in the source tree first.  hmmm.....
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
