[Gdal-dev] recent compile on cygwin?
Matt Wilkie matt.wilkie at gov.yk.ca
Thu Nov 15 13:43:21 EST 2007
Hello all,
Some time ago I was able to compile gdal on cygwin out of the box. Today
  it seems it's not so straightforward anymore. Has anyone else done so
lately? Any tips to share?
the error I'm running into at the moment is "cpl_port.h: No such file or
directory". That file does exist in the gdal/port directory. Perhaps I
need another one somewhere else too?
$ configure --without-expat
...snip...
$ make
...snip...
(cd port; make)
make[1]: Entering directory `/cygdrive/d/src/gdal-trunk/port'
make[1]: Nothing to be done for `default'.
make[1]: Leaving directory `/cygdrive/d/src/gdal-trunk/port'
(cd gcore; make)
make[1]: Entering directory `/cygdrive/d/src/gdal-trunk/gcore'
/bin/sh /d/src/gdal-trunk/libtool --mode=compile --tag=CXX g++
-DHAVE_MITAB -Wal
l  -O2   -I/d/src/gdal-trunk/port -I/d/src/gdal-trunk/gcore
alg -I/d/src/gdal-trunk/ogr -I/d/src/gdal-trunk/ogr/ogrsf_frmts
-DOGR_ENABLED -I
/d/src/gdal-trunk/port  -DPAM_ENABLED -c -o gdalopeninfo.o gdalopeninfo.cpp
libtool: compile:  g++ -DHAVE_MITAB -Wall -O2 -I/d/src/gdal-trunk/port
-I/d/src/
gdal-trunk/gcore -I/d/src/gdal-trunk/alg -I/d/src/gdal-trunk/ogr
-I/d/src/gdal-t
runk/ogr/ogrsf_frmts -DOGR_ENABLED -I/d/src/gdal-trunk/port
-DPAM_ENABLED -c gda
lopeninfo.cpp  -DDLL_EXPORT -DPIC -o .libs/gdalopeninfo.o
In file included from gdal_priv.h:50,
                  from gdalopeninfo.cpp:30:
gdal.h:40:22: cpl_port.h: No such file or directory
gdal.h:41:23: cpl_error.h: No such file or directory
gdal.h:50: error: expected constructor, destructor, or type conversion
before
....etc.
thanks,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
