[gdal-dev] GDAL and PROJ.4 in compiling
Mateusz Loskot mateusz at loskot.net
Mon Nov 26 19:58:36 EST 2007
Limei Ran wrote:
> Does GDAL 1.4.2 have PROJ.4 coming with the package?
Limei Ran,
What package you mean?
> I need to use PROJ.4 for projection transformation.  I have PROJ.4
> installed in a local directory on the linux server.  Do I need to
> point to PROJ.4's lib directory when configuring GDAL before make?
You don't need to point PROJ.4. GDAL will use PROJ.4 by loading it
dynamically in run-time if it's installed and available from standard
prefixes like /usr or /usr/local or other pointed by LD_LIBRARY_PATH
in your system.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
