[gdal-dev] GDAL and PROJ.4 in compiling
Limei Ran lran at unc.edu
Mon Nov 26 19:08:37 EST 2007
Hi:
Does GDAL 1.4.2 have PROJ.4 coming with the package?  I need to use
PROJ.4 for projection transformation.  I have PROJ.4 installed in a
local directory on the linux server.  Do I need to point to PROJ.4's
lib directory when configuring GDAL before make?
Thanks,
LR
