[Gdal-dev] Affine Transformation and Calibration Equation for
	Maptech/BSB format
    Christopher Barker
    Chris.Barker at noaa.gov
    Mon Oct  1 13:31:10 EDT 2007
Frank Warmerdam wrote:
> Internally GDAL can compute 2nd order polynomial warp
> equations from the reference points and this is what I
> generally encourage people to use (via gdalwarp) to
> convert the images to a nice "north up" image.
> But, in
> fact, I presume the files are actually normally in a mercator
> projection and that we would be even better off to work out
> the details of that and then use proper reprojection to get
> to other coordinate systems.
Hi Frank,
This is what I was referring to last week when I said goodbye. Yes,
almost all NOAA charts are Mercator (they may be a few that aren't near
the poles). It appears to be a limitation in the BSB drivers that the
projection info isn't picked up. Everything needed is in the text header
of the BSB files, so it shouldn't be hard to do.
That being said, a 2nd order polynomial fit to the GRPs is probably good
enough for most uses -- but I'm a purist.
I've been hoping for a while to dig into this and try to fix it, but
haven't had a chance yet. If anyone else does, I'd be glad to do a lot
of testing -- I should be able to get ALL the NOAA charts here, and run
tests against them.
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
