[Gdal-dev] How to Create a Geometry Filter
Kent Eschenberg eschenbe at psc.edu
Thu Oct 11 14:36:16 EDT 2007
Christopher,
Thanks! I found your routine in the C++ documentation but still haven't found a
description of WKB or WKT. Still, your example is one solid solution.
Kent
Christopher Schmidt wrote:
> One thing you might do instead is use CreateGeometryFromWKT. In Python,
> this is:
> ogr.CreateGeometryFromWkt("POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))")
