[Gdal-dev] How to Create a Geometry Filter
Christopher Schmidt crschmidt at metacarta.com
Wed Oct 10 17:23:36 EDT 2007
On Wed, Oct 10, 2007 at 05:03:12PM -0400, Kent Eschenberg wrote:
> Greetings,
> This is a combination complaint/question. I'm trying to use the layer
> classes' geometry filter to select only features in an area bounded by 4
>  points.
> I can't do that directly but must use SetSpatialFilter and first create an
> instance of OGRPolygon. I do so and look for a way to set the polygon's
> points.
One thing you might do instead is use CreateGeometryFromWKT. In Python,
this is:
ogr.CreateGeometryFromWkt("POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))")
to create a polygon in the first unit of the first quadrant.
I don't know exactly how this translates into C, but this returns a
wkbPolygon geometry type in Python.
Regards,
Christopher Schmidt
MetaCarta
