[Gdal-dev] Beginners question. How to fetch longtitude, latitude coordinates
Matthew Perry perrygeo at gmail.com
Fri Oct 12 13:39:25 EDT 2007
This page might be of some help,
http://mapserver.gis.umn.edu/docs/reference/vector_data/VirtualSpatialData
- matt
On 10/12/07, anakreonmejdi at yahoo.gr <anakreonmejdi at yahoo.gr> wrote:
> Hello all.
> Can someone provide an example of the configuration
> required to fetch data from mysql tables of longtitude, latitude
> coordinates?
> I need to display those data with MapServer.
> There is one table which contains information of the locations
> (name and other attributes) and a related table with the longtitude
> and latitude coordinates.
> It would be usefull if the example contained info on how the connection
> string is defined.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Matthew T. Perry
http://www.perrygeo.net
"Never ascribe to malice, that which can be adequately explained by
incompetence."
