[Gdal-dev] ng-python build
Christopher Barker Chris.Barker at noaa.gov
Mon Oct 15 13:30:12 EDT 2007
My thoughts on Python Bindings Building/installing:
William Kyngesburye wrote:
> As I worked on some OSX framework build issues,
NOTE: Thanks so much for working on this!!
> - After configuring to build ng-python, make doesn't build *any* python
> bindings.
> BUT, install does - the
> install-actions target runs a make install in the swig dir, which ends
> up building ng-python.
hmmm -- since you can define in configure whether or not you want the
bindings, I think "make" should build them. Does make call distutils? If
so, how does it determine which python to call it with?
> - ng-python installs in $prefix.  This ends up being installed
> where-ever GDAL is installed, in the subdir thereof specified in the
> python distutils (something like lib/python2.5/site-packages).
I'm confused now -- are they getting installed where GDAL is installed?
or in site-packages? Anyway, they should get installed in site-packages.
> Shouldn't it be left completely up to distutils so it gets
> installed in the default python site-packages dir?
Yes.
However, there are two things that get installed:
- The base gdal shared libs themselves
- The python extensions (and python code)
Which are we talking about here?
Anyway, I think the base gdal shared libs should bet installed in a
"global" location -- on OS-X that would be in Library/Frameworks, and on
other *nix , in /usr/local/lib (I think).
Howard Butler wrote:
> with the ng bindings, the situation is
> more inconsistent than that:
> -- If setuptools is installed, use that to build and do "install --root
> / --single-version-externally-managed".  By default this means an egg
> file gets put in your Python path (typically site-packages)
Sounds OK.
> -- If setuptools is not installed, install in --prefix as before.
This, I think, should put it in site-packages, like the usual setup.py
install.
> There are so many different ways to skin this cat now
Well, yes, but the python world has pretty much two standards now --
basic distutils, and setuptools, and, for the most part, people are
making those two behave similarly -- that's what we should do. (OK, you
-- I haven't figure out setuptools yet!)
> I think putting stuff in --prefix by default is
> confusing for most folks, but installing stuff in the root of your
> Python install isn't too friendly either...
But it is standard behavior. At some point, Apple had set up their
Python with site-packages outside of the system dirs (maybe in /Library,
rather than /System/Library), with a soft link into the system Python --
this was the "right" thing to do, I think, but it doesn't seem to be
standard behavior on any other *nix system (and I'm not sure Apple is
doing it either -- I haven't used Apples python for ages). Anyway, right
or not, it's up to the distributer of Python to set up -- distutils is
supposed to put things wherever the python it is run with says it
should, so we should follow that standard.
> As things are currently defined, setuptools is used *by default* if
> configure or setup.py determines that it is available. Regular distutils
> is then used if setuptools isn't available.
sounds good.
> I would hate to *require* setuptools.
Yes, we probably shouldn't -- *sigh* maybe it will make it into the
standard lib some day....
> Our default
> install: targets basically install the bindings the same way regardless
> of whether or not setuptools is available,
That's probably good.
> My opinions:
> -- I really like setuptools for the 'develop' target and even for eggs
> now that we use them on the osx buildbot slave (everything is
> self-contained and it doesn't end up polluting the rest of my machine
> with new and possibly broken bindings and we don't have to do sys.path
> hacking). I can see providing the ng bindings as eggs for windows, for
> example.
I agree -- that is most of the point of eggs after all!
> -- './configure --with-python;make;make install' needs to do the most
> straightforward thing for Python users
yup.
> (we need to define what that is,
> and it is my opinion that installing in --prefix *isn't* it).
no, it's not!
I think I've outlined my opinion about what it is above.
> Someone
> wanting to do fancier stuff should have to run setup.py themselves.
yup.
One more question though: How does configure figure out which python to
use? should there be a configure option to choose your python? could you
choose more than one? and have it build them all?
-Chris
> PS.  This discussion reminded me of the best feature of the ng bindings
> in the upcoming 1.5 release... docs!  I figured out a way to incorporate
> the doxygen docs into docstrings as part of the swig generation.  pydoc
> away... :)
cool!
By the way -- William, how are you building the Frameworks?
Is there a configure option ( --framework or something) that tells make
to build them?
Is a Framework build the default on OS-X? Should it be?
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R            (206) 526-6959   voice
7600 Sand Point Way NE   (206) 526-6329   fax
Seattle, WA  98115       (206) 526-6317   main reception
