[Gdal-dev] Re: [GDAL] #1878: programs can't find .o when linking
Mateusz Loskot mateusz at loskot.net
Sat Oct 27 14:58:03 EDT 2007
William Kyngesburye wrote:
>>> So, no problem with it on your recent OSX build where the OSR test
>>> failed?
>> William,
>> There is no problem with that anymore. I installed PROJ.4 and it works.
>> Simply, I forgot that I have no PROJ.4 on my new OSX box.
> What I meant was, when you built GDAL that time, did you have the
> .o/recompile problems?
William,
No, I didn't.
I've not experienced any problems related to .o files recently.
I rebuild GDAL on Mac, Linux, Windows a few times a day.
>>> It would have been obvious at least when make hit the
>>> programs.  You might have noticed the recompile when you installed.
>>> I forgot to ask - what version is your OSX system?
>> Mac OS X 10.4
> So, Xcode 2.4/GCC 4.  Same here - I thought maybe there was a GCC
> difference between our systems.
I have GCC 4.0.1 (build 5367), from XCode 2.4
Cheers
Mateusz Loskot
http://mateusz.loskot.net
