[Gdal-dev] svn build error
Mateusz Loskot mateusz at loskot.net
Sun Oct 28 02:05:21 EDT 2007
Joaquim Luis wrote:
> Lucena, Ivan wrote:
>> Joaquim,
>> The name of that library HD421md.lib could be related to HDF4.
>> But HDF4 flags are commented on make.opt:
>> http://trac.osgeo.org/gdal/browser/trunk/gdal/nmake.opt#L185
>> Is it possible that your make.opt has HDF4 flags uncommented by mistake?
> No, it's not by mistake. I normally build GDAL with hdf4 support but
> apparently the current (tonight's) nmake is trying to link
> against the HDF4 debug version. Hence the 'd' in "HD421md.lib"
I assume you GDAL build using Visual C++.
A day ago, I patched debug mode flags in nmake.opt in order to build
complete debug version of GDAL:
http://trac.osgeo.org/gdal/changeset/12549
Does linking with HD421md.lib work?
Cheers
Mateusz Loskot
http://mateusz.loskot.net
