[Gdal-dev] 1.4.3 build and NG bindings
William Kyngesburye woklist at kyngchaos.com
Mon Oct 29 13:27:50 EDT 2007
Either new or old python options should correctly find the Python 2.5
framework.  But I think Python needs to be in your PATH.  This is
correctly set when you install the Python framework, and there is also
an option to put symlinks in /usr/local/bin.
If you have another Python somewhere earlier in your PATH, this will
be found instead.
PS. a warning for Leopard users: Leopard includes python 2.5, properly
universal and 32+64bit (ie 4-arch), so you probably shouldn't install
the Tiger Python 2.5 framework on Leopard.  But also, that means that
python on leopard will try to build all 4 archs by default (for the
ngpython bindings).
On Oct 29, 2007, at 11:49 AM, Brian Hamlin wrote:
> Hi All-
>  I am still getting used to the details of GDAL/OGR. I found the
> output of the configure script to be a little confusing regarding
> NG, or Next Gen bindings and building. Howard Butler clarified it
> pretty well, so I am repeating that here. I hope this helps others
> with this build.
>  NG Bindings, or Next Gen, means SWIG. So if you are using a SWIG
> binding in any language, that is NG.   -  Originally there was
> python only, in a directory called pymod, and that alone is not NG.
> With 1.4.3 you can still specifiy the pymod python interface.
>  --with-python  => pymod interfaces
>  --without-python  --with-ngpython  =>  SWIG python, these are the
> preferred interfaces in the future
>  On the Macintosh, I have a new Framework python installed, version
> 2.5.x. Configure will not find that. You can tell configure to put
> your python support files in the framework python on the Mac. It
> seems to be this
>  --with-pymoddir=/Library/Frameworks/Python.framework/Versions/
> Current/
> hth
>  -Brian
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
