[Gdal-dev] OGR WCTS Win32 configuration
Bowerman,Dan [Burlington] Dan.Bowerman at ec.gc.ca
Tue Sep 4 14:17:13 EDT 2007
Hi Frank, thank you for your fast response;
Should the WTCS service be accessible through an URL like this:
http://mydomain.ca/cgi-bin/ogrwcts.exe?request=GetCapabilities
Or would I need to create a CGI wrapper for this to work under
Windows/IIS? Currently on my server, the URL above will prompt you to
download the executable rather than return the expected XML document.
Thanks,
Dan Bowerman
CABIN/NAESI Developer
http://cabin.cciw.ca/
Environment Canada
(905)315-5215
dan.bowerman at ec.gc.ca
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Tuesday, September 04, 2007 12:02 PM
To: Bowerman,Dan [Burlington]
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] OGR WCTS Win32 configuration
Bowerman,Dan [Burlington] wrote:
> Hello,
> I am interested in configuring the Web Coordinate Transformation
System
> as a service on our Windows Server 2003 webserver. I have the tools
> setup and they function properly through the command line as per the
> installation instructions at
> _http://home.gdal.org/projects/wcts/install.html_, however I am
> uncertain how to get this working as a usable web service that I can
> call remotely. Does anyone have experience with setting this up that
> might lend me some advice?
Dan,
Are you familiar with setting up cgi web services like MapServer?  It
should be similar in that you just copy the ogrwcts.exe and
wctsclient.exe
executables to your cgi-bin directory.  Keep the notes about the
PROJ_LIB
and GDAL_DATA environment variables in mind.  On windows the default
locations
to search for stuff is different, and you will almost certainly have to
set these two enviroment variables (perhaps as system environment
variables)
to point to where the supporting data files are.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
and watch the world go round - Rush    | President OSGeo,
http://osgeo.org
