[Gdal-dev] ogr / geos scripting question
Brian Hamlin maplabs at light42.com
Wed Sep 12 11:11:36 EDT 2007
I'd like to write a script to add a few points to a datasource, then
make some simple geos calculations on it.
  (I'm completely new to this)
below is what I came up with at a first look ( to simply create the
Data).
After creating the Data, I'd like to make a geos calculation, like
minimum radius for example.
thanks in advance
   -Brian / darkblueB
get OGR driver count
    iterate through drivers, looking for the desired named driver
datasource = driver->CreateDataSource( dir )
layer = datasource->CreateLayer( "layerOne" )
g = OGR CreateGeometryFromWKT( "Point( 10 100)" )
layer->SyncToDisk
I am a little lost about the need for features, or how to append my new
OGRGeometryShadow to the layer.
